Google Nexus 7 Tips and Tricks
Fairly obvious, but some people might not know.
You can go to the google play website and download and install apps right from there. At work I'll usually check that site and find a few apps. It will remotely send them to your device and when I get home they are installed and ready to go :).
Plus the interface is just a bit easier. It allows you to see what works with the Nexus 7. what doesn't... etc.
Went to Google App store and got "Indigo". Works well in the 7. I also use it on my Samsung Galaxy s2 phone:cool:
Had to type It in exactly as you had written. Used the mic and it separated the words and I could not find the app.
Have all of you knows that long pressing the WiFi and Bluetooth button on quick settings toggles them?
I got to use one of these puppies when I worked for Google on the Fiber project. My biggest tip would be to keep it near the charger, since it always seemed to be dead. I haven't been able to use any of the newer ones yet, but it did seem like it was a very well put together tablet.
pmm09
