Google Play Error Solution [RPC:S-5:AEC-0]
Im not an expert on these things, am a novice owner of a Coby Android Tablet. I have tried the removing and using another account method only, but it did not work. Was about to try the clearing data from the google framework method but am VERY glad that I didn't because I also read from other responses in forums that this method can cause more problems.
SO I just tried adding another google account to my tablet, so now there are TWO accounts (by the way sync is off on both accounts). Then run Play Store. At first it force closed. Then I ran it again and tried downloaded the app that i had difficulty downloading for the past few days (because i kept getting the RPC-error msg thing or the "can't contact google servers" message.) And thankfully, it downloaded the app successfully, whew!
Hope this helps, but if not, good luck using other methods :)
Edit: I tried downloading another app but the the RPC-error appeared again, so I just removed one of the two google acounts then added it again. Once more, it worked. Sort of, you must have one primary/main account, then remove and re-add the secondary to make it work again. Quite tedious but it works for now.
Re: Google Play Error [RPC:S-5:AEC-0]
ThhBinky, what a waste of time to post the same info as others have but require someone to register to view information that hasn't worked for many people.
I tried your methord many times but it didnt work for me... i am still and contineously having the error and after implimenting your methord i am facing new error like 529 and 503 error too :(................. please give another solution for this i dnt want to reeboot my cell phone again and again and to be very honest now i am so affraid of reebooting my cell phone because if i did then whats the gurantee that after reebooting my cell phone all app will be installed correctly???? :(
I have an Android Tablet, and I have been also getting the "Unfortunately...." messages. But I get the message for Google, Youtube, One word game, Clock and the main one was Email !! That was the first thing I Force Stopped !! All but the Email messages continued ! So I have now Force Stopped everything I received a message for !! Don't forget you may have to do this with several 'Google apps!' I just had to go back &
force Stop Google Partner ! I tried to only clear the cache &/or data on these, but it didn't work !! I had to go back & repeat the Force Stop with the Google Partner, & I added Disable, just to be SURE !! lol So far it seems to have worked ! It's sad we have to go thru this. I realize things happen, but if they'd only have a place we could look up to help, it may make it less annoying ! Hope 'THEY' are reading this !! GOOD LUCK EVERYONE !! And thanks for all the helpful hints !!
while deleting some file from my lg f160 i have deleted some main files by mistake after which i am facing this error while downloading from playstore
"error receiving information from server RPC:S-7:AEC-0...
PLEASEEE HELP ME
lencaiboncai178
