Google Play Store Not Working
Status
Not open for further replies.
hello i bought samsung galaxy s2 6month ago now i cant used my play store. it says probem with google system plz help me soon as possible thank you
Big thanks. I was so frustrated that I wanted to return my 3 mini. Google keyboard was installed but google PINYIN is not working, but you cannot help me with this part. ^_^
I'm using S4 just bought it like 1 day ago .. I was downloading a song and it took forever and a text pop out and said if you force close it will affect your other apps and I did not really care about it after 10 mins time I wanted to download something and I press on the icon play store it will appear for 1 sec and disappear it will bring me back to my home screen :( please any solution ? And who is this guy :( ? fiendishmcbutton ?? Pls help :(
I'm so grateful for this remedy. I was about to Factory reset my phone. But thanks to u, all my data and time is saved.
I haven't read through all the posts on this thread, but my S3's Play Store wouldn't connect and the fix was to re=set the date and time. The date and time was off by over a month. Later, Ray
Google Play Store reported 'No Connection' when I tried to Accept and Download new Android apps for my INQ Cloud Touch phone, even though I had a good WiFi connection, and my Gmail and browser worked fine, and I was able to search for new apps on Google Play Store.
The solution was to Uninstall all Updates to the Google Play Store application, so that it went back to the original factory-installed Google Market application. Then, after restarting the phone, the downloads process worked just fine. Unfortunately the application seems to automatically update itself, so I have to do this Uninstall Updates to Google Play Store each time I want to install a new app. It seems that Google Play Store now does not work correctly with my phone and Android 2.2.1 (even though it did for a while).
Before I found this solution I had tried the following suggestions, without success - correcting the Date and Time (mine was not wrong in the first place), and clearing the Cache for Google Play Store and Google Services.
Situation: You pick up your phone and launch the Google Play Store to download an awesome new app, and to your frustration, it force closes before you get the chance to and are left with this little present of an error message (minus all the cool neon aqua accents that I drew in above). Can it be fixed? Yes. Can it be fixed without erasing the phone? Yes again (well most likely). ?How do I do this?? you ask yourself?continue reading?
1. Go to Settings.
2. Then Application Manager.
3. Make sure you are on ALL applications.
4. Find Download Manager. They are not all listed alphabetically. You may have to scroll to the bottom of the app list to find this.
5. It will probably say disabled. Click Enable.
?If you are still having problems after performing this step, go to Settings > Accounts and Sync > your google account then uncheck ?Sync Internet?.
?You can also go into Settings > Application Manager > All > Play Store > Force Stop > Clear Cache > Clear Data.
i have samsung galaxy ace duos...& google play store is not working...saying stop unexpectedly please give any solution
Re: Google Play Store Not Working [THANKS FiendishMcButton!]
Me neither. I cannot access play store or any update all app. Some one pls help me... I'm using tab 10.1
Remove your account and restart your phone.
Sent from my GT-I9505 using Tapatalk 4 Beta
Google play store is not working says unfortunately Google play store stopped, mistake by me on Iinstall my mobile is Samsung galaxys advance plz help me!
My play store is not working says unfortunately Google play store stopped,"mistake by me on install,my mobile is Samsung galaxys advance please help me!
Did you Uninstall your play store by accident and then reinstall it?
Status
BekaH
