Google Search Battery Drain
cmd280
10
Hey all,
Used my phone heavily yesterday and when I went to check my screen on time (a little over 4 hours) I noticed that Google Search ate up more battery than my screen! My gps is set to battery saving FYI.
Not sure if that is normal though, so I figured I'd ask you all.
Thanks!
This certainly isn't normal! I would always suggest a simple reboot which should fix the issue and then monitor in the future. If it doesn't happen again, something clearly went wrong on this one occasion. If it comes back then it's worth investigating further.
Try a restart and if that doesn't work, a cache reset.
Sent from my Nexus 5 via the Android Central App
lencaiboncai178
