- Mar 31, 2015
- 9
- 0
- 0
Hi all.
Google just introduced new "Tap to Translate" feature of Google Translate.
However, I don't think this is most convenient way to get text translated. Too many taps are required and you can't translate text from third-party apps that don't allow native text selection.
We've created an app that adds real "Tap to Translate" feature to Google Translate. This app is not translator itself, but it provides much more convenient way to pass text to Google Translate.
You can see below video to see difference between original Google Translate's "Tap to Translate" feature vs Google Translate's "Tap to Translate" feature provide with our app.
Full description of our Tap to Translate app is listed below.
Introduction
Google Translate is one of the greatest apps on Android.
By adding in-app translation ability it becomes even much better!
However, Google Translate can't translate text in third-party apps that don't support native Android text selection method (long click and highlight).
So, we've created Tap to Translate!
Tap to Translate allows you to select and translate any text on screen by most comfortable way: just tap to translate!
Tap to Translate brings Google Translate to new level of convenience!
Review at AndroidHeadlines: Sponsored App Review: Extension for Google Translate | Androidheadlines.com .
Main features:
- Selection of single or multiple on-screen text blocks at one time.
- Instant translation to your language by Google Translate.
- Easy access, activation or deactivation with floating icon.
- Auto-starts with selected apps.
How to use:
- Launch Tap to Translate
- Click to Tap to Translate's floating icon to activate text selection mode. For the first time, you are requested to enable Tap to Translate in Accessibility Service Settings.
- Click to on-screen text blocks to select text.
- In single text selection mode (default), Google Translate takes action at once and translates selected text to your language. In multiple text block selection mode, you have to click to EFGT icon again after selecting all text blocks.
- Click back button or re-click Tap to Translate's floating Icon to disable text selection mode.
- Tap to Translate's floating icon can be moved anywhere on the screen by drag&drop. Moving to X icon at bottom will shut down Tap to Translate.
Settings:
- Settings page can be open from System's Accessibility Settings, or by relaunching Tap to Translate while Tap to Translate's floating icon is already active.
Notes:
- Tap to Translate needs system's accessibility features to see what text on screen.
- Tap to Translate can work with many apps. However, some times Tap to Translate can't recognize text on screen, especially for app with web browsing view.
- In few cases, Tap to Translate can detect on-screen content changes and auto deactivates text selection mode. You have to manually re-enable again.
- Google Translate is product of Google Inc. Tap to Translate has no relationship with Google, Google Translate or its affiliates.
Download
You can download the app from Google Play Store
https://forums.androidcentral.com/e...tails?id=com.vnspeak.translate&token=10jwNTTf
Thanks.
Introduction
Main features:
How to use:
Settings:
Notes:
Download
Thanks.
