GPS No Workie Without Gear S Data Plan (without a phone connection)
Ok, maybe not. Since it has Glonass maybe it works. If you have a Gear S does GPS work standalone without Data?
Common misunderstanding about A-GPS. You want A-GPS so that it can get satellite lock quickly (within 10 seconds instead of 5 minutes) if your Gear S has its own data connection. A-GPS doesn't mean it is not using GPS satellites at all.
Thanks for the clarification
Sent from my Samsung Note 4 using Tapatalk
That's not true. The Gear S has GPS that works without the smartphone. So does the wifi, 3G, etc.
I had to be outside to get a lock on gps
That's true for all GPS devices in general. Some may have better GPS antenna than others. But a good GPS antenna is bigger than the watch. So something gotta give.
The biggest problem with GPS on Gear S is the Here Map won't start navigating if you don't have the phone tethered with BT. If I have the phone with me, why would I use the watch for navigation in the first place.
It works fine with out it.
No, it won't let you start navigating (the play button is disabled) if a phone is not tethered via BT.
Ah. That is strange. These apps need to be updated to support the Gear S standalone
McAllister81
