ihbsbA
- May 16, 2010
- 1,417
- 5
- 0
I don't think it is a settings problem (or at least it isn't in my case) It is likely a bug in the firmware. The only workarounds I have are to reboot and play with the roaming settings until it works.
You should verify if we are talking about the same problem. Regardless of whether you are 1x or 3G, the notification bar will always say 3G. To tell whether you have a 3G/EV connection or 1x, you can do ##DEBUG# in your dialer and look at data status. If you already 3G/EV, then you have a different problem, possibly Sprint is just slow.
Or are you saying you have no data at all (as in it doesn't say 3G in the notification bar)?
Correct, there was no 3G in the notification bar. Just my singal strength with a triangle over it and the message telling me that my data connection was gone because I was roaming.
Sent wirelessly with Tapatalk.
