A couple days ago the amazon free app was Everlands, and I noticed they also had Everlands HD.  I was curious so i downloaded both.
Using Drew's Stable2 release-
Everlands:  Works mostly.  Occasional ~15 second hiccups where nothing moves and if i try to do anything I get a force close option, but if I wait, its fine.  and occasionally the animations (one hex attacking another hex) are extremely slow, lasting ~15 seconds.
Everlands HD: Would not load properly, once it mostly loaded, but there were artifacts.
I gave Everlands HD a try on Reborn, no problem.
Since Everlands is a pay app, I wanted to find a different (Free) app as an example.  I searched HD found Robotek HD by the same company.  It plays fairly well on CM7, but if you look at the attached picture, you'll notice there is a graphics problem.  one of the layers appears to be missing.  The CM7 is Drew's Stable 2 the only steps I did was install market, titanium backup, and sign in (with no restore) to my google account.
List of games I've seen similar issues to varying degrees during
Plants Vs Zombies (Pop Cap Games)
Inotia3: Children of Carnia (Com2uS)
Everlands HD, Everlands, Robotek (Hexage)
Fieldrunners HD (Subatomic Studios)
==> I would say it sounds like my phone, but in every case, Reborn works just fine.
==> It doesn't appear to be application specific or even developer specific.
==> please post if you have tried running PvZ, Everlands HD, Robotek HD, Inotia3 on a fresh installed CM7 ROM.  I'm trying to find out if this is a phone specific problem or not.  It sounds like only 2 people have the same issues. ens04@Fieldrunners and sjc11221@PvZ
PvZ - inital loading screen, if you dont let your phone sleep, will not appear to load (but kind of does)
Everlands HD - Doesn't load well
Robotek HD - the map is missing the land outlines
Inotia3 - occasional pauses, 80% of the time there is a dialog sequence, the dialog windows become corrupt or shortly after will crash
