mak916 Well-known member May 17, 2010 663 169 43 May 6, 2017 #1 Anyone using GSam Battery Monitor been able to "enable more stats"? For some reason I can't get the adb to work.
Golfdriver97 Trusted Member Team Leader Moderator Dec 4, 2012 35,590 541 113 May 6, 2017 #2 How did you set up ADB? Edit: ADB commands also only show a message when something isn't right.
mak916 Well-known member May 17, 2010 663 169 43 May 7, 2017 #3 I finally got it working. I was missing a step. Thanks for your help.
F Formula1Fanatic27 New member Feb 17, 2014 1 0 0 Jul 15, 2017 #4 I'm having the same issue. What step did you miss?
GSDer Well-known member Jan 30, 2011 8,469 15 0 Jul 16, 2017 #5 Formula1Fanatic27 said: I'm having the same issue. Click to expand... What 'same issue' are you having? Does 'ADB devices' produce the correct result?
