GSAM Battery Monitor Question
Benjamin_NYC
Banned
May 15, 2014
1,068
In Time Remaining, I assume Average is the likely time remaining based on my typical use. Talk Time is if I just talked, I guess. What is Last 15m??
Do you have a screen shot?
dpham00, Android Central Moderator
Sent from my Verizon Moto G
That app is a little weird. It doesn't have a clear explanation of that.
There are three things under Time Remaining. Average, 1m (or 15m, it changes) and Talk Time. I'm asking what 1m/15m means. What does that mean?
I've understood that to mean based on your last 15 minutes of use, this is the amount of time your battery has remaining. Sometimes the time will also vary, like Last 1M, 6M, 9M...but it just means based on your usage in the last whatever minutes that's posted, that's the amount of time your battery has remaining.
I tent to pay more attention to the average time remaining.
Trojanman is correct--the "last 15 minutes" estimates your remaining battery life based on your usage in the last 15 minutes. This may be important, because if your device has been on standby for a while, then the estimated remaining battery life based on the last few hours may be grossly overestimated if you started using the device more intensely in the last 15 minutes, and intend to continue doing so.
araelbenjie
