GSIII Screen Question
I cant stand how HTC Sense keeps crashing and reloading on even a small task. Id use the internet and when id try and go back home Sense would crash and id be stuck with a loading screen. I do agree the S3 screen in sunlight isnt that great but I cant look past it.
I had the same choice..... I did a lot of research and I chose the Galaxy SIII. I'm glad I did.
I'll say it, yes, in my opinion the Evo LTE has a better screen. Does that mean the Galaxy SIII screen is terrible? Definately not. Far from it. It's still stunning.
If the Evo LTE had two gigs of RAM then it would have been a harder decision. 1 gig for the Evo is just too little. 700ish meg of RAM is automatically used by the OS leaving the rest for Apps. For the Galaxy 1 gig RAM is dedicated to the OS leaving 1 full gig for any apps. Huge difference. This is the cause of the Evo's multitasking issues and Sense crashes. I came from the Evo 4G and it's biggest flaw was internal memory (ROM). I promised myself I wouldn't make that mistake again. I got the 32 gig version with a 32 gig SD card. I have already downloaded a couple apps that are a gig in size and it's nice to not have to worry. With no app to sd yet for either phone even 16 gig will go by fast considering you're stuck with the phone for hte next 20 months.
To each their own.... but I made the right choice.
According to samsung an app over 1gb can be moved to the sd card. So that really large apps don't take internal storage.
_______________
Just Flash It !!!
lumaplay
