- Dec 4, 2012
- 35,746
- 828
- 113
Hi,
I have a nexus 5 and I tried to disable any google app such as hangout and it worked well going through system>apps>all choose one and press disable.
However 2 are resisting and those are the ones I'd like the most to get rid off: 'Google Search' and 'Google Now Launcher' (I'll use Nova instead)
Those 2 have the 'disable' keyword keyword grayed.
Anyone knows how to disable those?
I actually managed once to disable 'Google Now Launcher', 'disable' was not grayed and then when pressing home nothing was happening(I did not have Nova installed). Worried of the situation, I put it back and now I can't remove it again. Just to say that there must be a way, maybe a bug in Android at that moment...
Anyway, if anybody knows, please share.
Cheers,
Google search is integrated heavily in the ROM. I would just install Nova and let Google launcher just sit. I personally like having a launcher active just in case something happens to the one you are using.
Signed, an M8, Liquidsmooth, and the AC Forums App
