[Guide] How to Root the Samsung Galaxy S5
I've got the G900F on Three (Ireland) network. I don't think they do anything to safeguard against rooting. Had zero problems a couple of years ago with same carrier, S3, some earlier version of odin, custom recovery, various custom rom experiments etc. I'm just slightly nervy as the one time it could go wrong could go wrong might happen to me. Is there any way that Odin / Download Mode on the phone can be messed up somehow or is that in protected storage? As long as that's operational I know it's never truly bricked.
It's pretty fool[proof on the Galaxy S5 international model, G900F. No locked bootloaders to worry about. Just a straightforward flash of the CF-Auto-Root kernel, to replace stock, using Odin. See post #36, above, for download details and links.
Hello,
Could someone please advise on how to root Samsung S5 Duos ( i want to root in order to try to recover deleted sms texts):
SM-G900FD
Andr. 5.0
Baseb. G900FDXXU1BOE1,G900FDXXU1BOE1
Kernel: 3.4.0-4516970
dpi SWDD5815 #1
Tue May 12 13:27:06 KST 2015
Build no: LRX21T.G900FDXXU1BOE2
SE for Andr. stat.: Enforcing SEPF_ SM - G900FD _ 5.0 _ 0027
Jul 17 01:25:27 2015
United Arab Emirates
TRA ID: 0016333/08
TA:00000000/00
Security software ver.:
MDF v1.1 release 4
VPN V1.4.release 3
KNOX ver:
KNOX 2.3
Standard SDK 5.3.0
Premium SDK 2.3.0
Customization SDK 2.0.0
Container 2.3.0
IM 2.0.0
CEP 2.0.1
SE for Android 2.2.1
SSO 2.1.1
TIMA 3.0
VPN 2.2.0
Your help is greatly appreciated!
Thanks!
Hello,
SM-G900FD
Andr. 5.0
dpi SWDD5815 #1
TRA ID: 0016333/08
TA:00000000/00
MDF v1.1 release 4
VPN V1.4.release 3
KNOX ver:
KNOX 2.3
Standard SDK 5.3.0
Premium SDK 2.3.0
Container 2.3.0
IM 2.0.0
CEP 2.0.1
SSO 2.1.1
TIMA 3.0
VPN 2.2.0
Thanks!
Hello and welcome to Android Central Anca Balogh Wittman!
The following step-by-step guide should help you root your phone...
How To Root Galaxy S5 Duos SM-G900FD
Hi, my goal is to root in order to remove bloatware. its my understanding that the new stage fright update has made some of the older root methods obsolete. Im looking for the proper files and guide I need to do this.
Thanks in advance.
I have a Sprint gs5 sm-g900p
Android Version - 5.0
Baseband Verson - G900PVPU3BOG1
Build Number - LRX21T.G900PVPU3BOG1
Thanks in advance.
No, the Stagefright patch makes no difference. Rooting as normal for Sprint users...
[SM-G900*] CF-Auto-Root
Hello Subhasis Pramanik,
I have the same model like you also with Baseband Verson - G900FXXU1POEC and Build Number - LRX21T.G900FXXU1POEC. Can you tell me if this rooting procedure worked for your device without any issues?
Would be very nice if you could tell me :)
I have an S5 that I would like to root, but it's Verizon. Tried KingoRoot but it could not do it. Here is my info:
SM-G900V
Android Version 5.0
Android Security Patch level 2016-02-01
Baseband Version G900VRU2BPB1
Kernal Version 3.4.0
KNOX Version 2.3
As a side note, I can't get my computer to show my phone when I plug it in. Fairly certain it's not my antivirus but not 100%. I've been trying to get photos off of it, but it's not working.
Thanks.
angelag5098
