[GUIDE] Nova Launcher
Thanks - I'll give that workaround a try. Can maybe use it to reconstruct a grid like the old one. I'm looking at reducing the number of home screens on the tablet anyway, but it's quite useful to have a different screen for each function (mail, video, radio/music, games etc).
Welcome! If you create a folder with Nova you can have a 3x3 grid similar to the one you're talking about.
I just received my Galaxy S6 and I no longer have the option for Home Screens under the Desktop selection. Big problem as it only allows me on home screen. HELP!
Yep, works fine (although Simple Text is a bit of a pain to use, but got it set up). I've jettisoned a screen and replaced the app drawer icon in my dock with the folder (using the app draw icon I moved out to fill the 9th part of the 3x3 grid). Would still be nice if we can have the built-in grid back though, either as a switchable replacement for the scrolling overview, or perhaps an additional button at the bottom of it alongside the wallpaper/widgets/settings ones. But the folder work-around will certainly do for now as a replacement.
Given your comment about hearing a lot of complaints about this I presume you're a dev or similar involved with Nova? Have to say aside from this little niggle it's one of the nicest apps on my tablet and a must-have.
Glad it worked! No, I'm not a Nova dev, just a big fan :)
With Simple Text the best thing is if you create your own model, so anytime you use it you don't have to define your preferences.
After the latest update you have to press & hold on your homescreen and then you can see the screens overview.
Great guide. I want to copy a couple specific TouchWiz folders to my Nova pages. Is there a way to do that?
I just had to do a factory reset of my Note 10.1 2014
I LOVE Nova, and of course re set it up on the freshly reset Note
One small issue, that I cant seem to figure out, when I choose my wallpaper, it puts it on my screen , with like a white dotted line , almost looks like stitching, around the image. Any idea how to correct this, so I JUST see my image and no white dotted/stitch line?
Here is what I see:
Thanks
Diane
That's one of the good things about backing up Nova settings and store them elsewhere as there are so many tweaks/features you can choose from. Those are apps scattered all over the place instead of in your app drawer, you can also put your favorite ones in the doc area...but I could be wrong, you need to have the dock feature turned on and a white icon w/ dots should be in the center....when you tap that all your icons show up...you can also determine which you want to hide like wallpapers, etc in the app/widget/drawer settings...If I can figure it out, I'll attach 2 examples from my Note 5 phone
Here is what I see:
Thanks
Diane
On my phone, I see a dotted line in the center. There's an icon above to turn it on and off. I believe it's a guide to show you now much your desktop will show on a particular screen, or how much will be displayed on a particular home screen (e.g. my phone's home screen).
NVK
