Guide to rooting phone with HBOOT 2.18.0001
Unlocking is only the first part of the process. You now have to root.
That requires flashing a custom recovery, and then Superuser, so that you gain root access and can uninstall the bloat. Or, alternatively, you can flash a stock rooted or custom ROM with the boosts already removed.
Current ROM (BootManager Slot 3): MikG v3.11 w/ICS Lite Theme - Kernel: AnthraX TEST #9
I have my EVO 4G rooted and unlocked. I just can't seem to get my S-OFF. How do you do that?
Thanks in advace!
Rob
Thanks in advace!
Rob
Why do you want S-OFF?
With the unlocked bootloader, you can flash custom ROMs and kernels with a custom recovery. Since you're already on the latest firmware, there really isn't much advantage to being S-OFF unless you really know what you're doing (i.e. you're a power user and aren't afraid of accidentally bricking your device).
ROM: MikG v3.11 w/ICS Lite Theme | Kernel: Underworld v0.4 SBC
Please help - I have spent untold hours trying to root my Evo 4g so that I can install wireless tethering. I rooted my older device using unrevoked last year, but apparently the new model is much more complicated.
I am trying to follow the process under "[Revised] Rooting Gingerbread 2.3.5 Dummies Guide" using the HTCdev method. In HTCdev, I have made it to step 8, typing in the "fastboot eom get_identifier_token" command, but the text that comes up is not the identifier token. It says:
usage: fastboot [<option>]<command>
commands:
update <filename>... etc, on & on, listing several commands
options:
-w... etc, on & on, listing several options
Any help to get me all the way through as quickly as possible would be so appreciated!
I feel like the process is so nested: "All you have to do is X [just make sure you've already done Y [for which you should know you had to do G [but in order for that to work you really need Q..."!
hey guys im experiencing a problem... I have my HTC Evo 4g unlocked via HTC dev but I am having trouble flashing a custom recovery. I put the file on my SD card and it says, "Update failed". Can anyone help me flash a custom recovery? I am using a mac.
I'm stuck again! My bootloader is unlocked, and now as I to install the custom recovery, am stuck again. I have tried both methods listed in the step-by-step, as well as a method I found on YouTube, and they all fail. Method 1 stops me at "waiting for device" in the command prompt after I enter the command given; Method 2 fails because I installed Android Flasher (or whatever the exact name is) but my computer tells me I need to have another program installed in order to run it, and then it won't let me install that program. The YouTube method - which attempted to get me to load the recovery file directly onto the SD card and then fastboot (i don't know what beyond that) fails when I try to fastboot - I get a message on the white screen of my phone saying "Main version newer! Update failed". Please help me through this. Thanks so much!
For the Fastboot method to work, the device has to be in fastboot mode. That means the white screen with the Androids on skate boards at the bottom. You have to press the power button with the "FASTBOOT" option highlighted, so that it changes from "HBOOT" to "FASTBOOT USB" when connected to your computer. Then you can issue the command to flash the recovery img file, and it should find the device. If that doesn't work, you can put the file from here on the root of your SD card, and flash the way you tried in your third method. But my file should work ;).
Reactions: cmcdanald
Thank you - your file did work. Now trying to install the mikg - do I download the full wipe and the update?
I'm stuck on step 13 - once CWM recovery boots on your phone use the volume up and down to pick Mounts and storage press power to select it
My phone gets to the start screen that says hTC EVO 4G and just hangs there. What did I do wrong?
Thanks.
Thanks.
I'm assuming step 12 worked ok, which should have flashed the recovery. Take out the battery and put it back in after a min or so. Hold volume down+Power on and it should kick you into Recovery. Hope this helps. Pick-up step 13 if you are in recovery.
So, my EVO 4G booted up with just pushing the power button this morning, however, I didn't get the prompt for Mounts and storage in Step 13.
So, I pulled the battery and did booted from the recovery and now my EVO is in a power cycle that doesn't seem to be ending any time soon.
I have the battery pulled, what do I do now?
This is what I get after step 11:
sending 'recovery' (3120 KB)...
OKAY [ 0.906s]
writing 'recovery'...
OKAY [ 1.406s]
finished. total time: 2.313s
Now, I'm in the screen that the menu items are Bootloader, Reboot, REboot Bootloader, Power Down. Which one do I go to? Or should I be in the menu level above this one?
Thanks.
You only need to download and flash the v3.11 Full Wipe version. The update is for people that were previously using v3.1.
Enjoy your custom ROM!! :)
If I just choose to unlock the bootloader (via HTC dev,S-on) can I still flash a custom Rom or do I have to also get S-OFF? I want to root this thing but I want be able to tinker with custom roms, not quite ready for kernels or radios yet though. Help is appreciated
Well, I am not getting much further on this. I see that I have the bootloader unlocked now and I can hook my phone up to my computer as a disk storage device. I'm not sure on how to:
17. select go back
18.select install zip from sd card
19.choose zip from sd card
Where do I do this step?
Corey
I'm having the same issue others are:
Follow all steps
Download clockworkmod image
Rename "recovery.img"
Place image i same folder as fastboot files
Navigate to folder in cmd
Paste "fastboot flash recovery recovery.img" in cmd
Result is error: cannot load 'recovery.img'
I'm 99% sure I'm doing everything correctly. Can I use some other image to test if it's the file or me?
Well, something is really wrong with my phone now. I can't get it to boot up and of course Sprint is no help now that the bootloader was unlocked. I tried relocking it, but they knew it had been done so they just threw their hands up at me and said to call the insurance company since I have total protection.
When I go to the fastboot and it does some little check, I can't tell what it's looking for, but I see that it says the file isn't there or cant' load or something. Says it for like 3 different files.
I need some help here folks. This is my only phone!
OK, here is what my screen looks like when I get to the boot menu:
Unlocked
Supersonic EVT2-3 Ship S-ON
HBOOT-2.18.0001
MicroP-041f
Touch Panel-ATMEL224_16ab
Radio-2.15.00.12.19
Dec. 21, 2011, 12:50:32
I get a success message when I flash the recovery.img file.
sending 'recovery' (4004 KB)...
OKAY [ 1.094s]
OKAY [ 1.719s]
finished. total time: 2.812s
However, when I go to recovery on my phone and try to boot the phone it goes into an endless restart loop. If I take out the battery and let it sit for a minute I can boot normally, but I don't get the following step:
13.once CWM recovery boots on your phone use the volume up and down to pick Mounts and storage press power to select it
What do I do?!
Thanks.
heritagevine20
