[GUIDE/VIDEO] Root Gingerbread on your Incredible 2 (2.3.3 ONLY!)
Re: [GUIDE/VIDEO] Root Gingerbread on your Incredible 2 (2.3.3 ON
When I enter my Beta key then hit enter, it says "Zerging root...this might take a minute or so..." for like 3 minutes then it says "Failed to get root!"
idk why, help me! My phone is 2.3.3
You put in the correct serial number that was found and followed all the steps I assume. Double check everything to make sure it is setup correctly before proceeding. One little thing that is off can cause it to fail.
Yes I did.
I tried it again and it just said "Zerging root...this might take a minute or so..." for like 10 minutes straight
Hmm thats weird. Did you downgrade from 2.3.4 to 2.3.3?? And I am sorry for this, but you did select the correct phone model on the Revolutionary site right?
*edit* Also have you made sure you HBOOT is indeed .97??
I was never 2.3.4, I'm currently 2.3.3. I read the wiki, and I selected the correct phone model. By HBoot if you mean on the Revolution website then yes, its the only one there
EDIT:3 days later i decided to try it again and it worked!
EDIt2: God dammit SuperUser isn't in the app tray
EDIT3: Well I downloaded BloatFreezer and its letting me use it so I guess it worked!
Just look up superuser in the market and download it
Sent from my Incredible 2 HD using Tapatalk
Everytime I click on the superuser.zip download link it just takes me to their website and isn't letting me download it. Just keeps refreshing. I went ahead and downloaded their zip software thinking that would let me do it. No luck. Why can't i download the superuser zip file? THanks.
A little late but the link works fine for me. Try this
So after following the steps above i'm rooted. Whats the difference between rooting my phone & adding cyanogen stable mod?
Thanks
Micko
Thank you for this...I was able to root my dinc 2 and me being a "newbie"
Chris
Re: [GUIDE] Root Gingerbread on your Incredible 2
I can't get the fastboot drivers or Superuser.zip. :-(
ahsokacat
