guys need help ASAP
Sep 2, 2015
19
So my android tablet has a problem
1.When I turn on the WiFi the screen brightens for a few seconds then the WiFi switch turn off but on the screen it says turning on WiFi
So I think the reasons are
Overheating (playing while charging)
Rooting
Dead space(when I'm playing the brightness turns to the max and when I'm charge and playing when I accidentally pulled the charger the screen flicker like crazy)
I'm using android rooted polaroid executive clavier (4.2.2) mid0880
Thanks guys
Posted via the Android Central Appw
So I tried experimenting today I put the brightness to the max and I was shock on what I saw
Every time my tablet flickers on brightness max I saw white lines as big as my fingers like 4 of them on my screen
Is it my screen or should I just do nothing and let it fix itself
Uhmmm something happened again so I was testing if the WiFi problem was fixed I tried to open WiFi and close it and open it then suddenly screen goes crazy flickering bright to dim
Welcome to Android Central.
Whatever it is, it sounds bad. A visit to a repair shop for diagnosis may be best.
He also said that it might be a part of the screen loosen up because before I had my tab dropped from stairs and caused a bit zigzagish crack
But what is the connection of it on my not turning on WiFi???
pcjordanellis
