Handcent MMS not working - Sense Messaging Does
MrJedi
Active member
Apr 28, 2011
33
5
Anyone else using Handcent have a similar experience? The messaging app is decent, I just got used to using Handcent on my last two phones that it was the first app I installed. It tries to send MMS but after and hour or so it eventually fails. The regular app does it in minutes. Not sure if others have experienced issues, or seen any fixes.
I had the same problem.. So i just deleted the app and started using the stock messaging app again
I had this issue as well. Removed the app, emailed the developer and waiting to hear back...
Sent from my HTCEVOV4G using Android Central Forums
fhsfayt356
