has anyone setup tmobile with their 3g nexus 7?
To set up T-Mobile: Put the sim card in and turn on the device...
1. Go to setting and turn off wifi.
2. Select Data Usage\More and select Mobile Networks
3. Select T-Mobile
4. The Pull Down notification center will show a ? mark on the cellular bars
5. Pull down the notification center and there is a selection for t-mobile activation
6. A web page opens with the activation form...
Also if you mess-up and don't get the notification panel... Just open Chrome and it will go to the same page with wifi turned off...
If this helped you... Visit iMindAmbiEnce.com and check out our new app...
