Has Anyones Battery Life Changed Recently?
Ok so this happens because of Google location sharing .Google keeps on sharing your location every minute to check where u go,so that they can give u suggestions about nearby places etc etc.
To disable just go to Location and disable location sharing.you will still be able to use GPS flawlessly ,it's just that everyone it won't be sharing your location deatils.
This is common for all phones.i hope Google fixes this ****ty thing.realy annoying to see such things
Mine seems better, probably because the initial novelty has wore off and I’m not constantly playing with it. I get around 30 hours with about 4 hours on screen. I came from an S6 edge so the battery life on the Note 8 is a revelation.
No change here battery goes 12 to 15 hours of heavy use all day long. Email, photos, text etc still running strong.
All i see is under Location settings is Location Services:
Google Location History (which is on)
Google Location Sharing (which says I'm not sharing my location with anyone)
You know what would help here is if you could go back & edit your post with the software version number :)
This is mine today and I use it alot.
I have noticed a sudden change for the better. When I first got the phone I would be down around 20 - 30% at the end of a full 16-hour day. Now I'm barely hitting 50%. Weird. Not complaining though.
Nothing bad to report here. It's the same as it has ever been.
At least 5 hours of on-screen time, over 1-2 full days, at most 7.2 hours over a 20 hour day.
off8485
