Is there anyway to fix this? It's really annoying.
If you don't know what I'm taking about, it's when you get a call and either the volume is too low or tool high. You can't adjust the volume with the side control unless you first pull the phone away from your face for the screen too light up. I'm guessing they did it so you don't accidentally change the volume while on a call, but I find it very annoying
