Have two issues that I need help with... (BAMF 1.0.9)
MhzMonster
48
Running [2.11.605.5][Sense3.0]BAMF Forever 1.0.9
have two issues with this ROM that I cannot find any answers to, hopefully someone can help resolve it.
1.When I go to the top pull down where the notifications and quick settings are at, I tap to check/enable the Mobile Hotspot but nothing happens (no check, doesn't enable it). It does work when I go through the settings and enable it that way, and then look at the quick settings it shows its enabled with a check. The shortcut in the quick settings is faster. Also, any way to change whats listed as a quick setting?
2. When Connected to a computer through USB, on the stock ROM I could go into setting>Connect to PC>Default Connection Type> and set it to Internet connection mode. So when I connected my phone to my computer it would automatically enable Internet Connection Mode. Since I've loaded Bamf Forever 1.0.9, I no longer have this option under Default Connection Type and have to manually enable ICM each time.
Droidikon22
