Having a Problem with Sending Texts
itsFroyo
So my boyfriend also has a Samsung Galaxy S3 and has been complaining that my texts are arriving much later (usually 15 - 30 minutes) after they send. When they do arrive they arrive all at once. I was wondering if this was a problem with my phone or his. Also, what can I do to fix it? Another problem I've been facing is sometimes when I call someone it'll sound extremely robotic and choppy, even when I'm just in my room. Any help in these matters would be super appreciated!!! Thanks for reading!O:-)
Are you both on the same carrier?
Are you both using the same Messaging app?
If you're sending SMS (no attachments, < 160 characters), that totally relies on your cellular signal - what kind of signal do both of you have (3 bars or more, hopefully)?
What happens when each of you text someone else - does that go through normally?
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
Depending on the carrier, you could try updating your roaming capabilities. On Verizon I believe you dial *228 and select option 2.
njira
