Having Problems with Xposed on my S6
taga
Guys, every time I try to install Xposed for my SM-G920F (I´m 100% sure that I use the correct files every time), my device reboots after entering the pin code.
I had already flashed stock a completely new stock rom via Odin, Wiped Data/Factory Reset and installed XtreStoLite newest version.
Nothing helps.
I remember I did something wrong with "Kernel Auditor" in the past. (I think I done something with "Enable on Boot") Since then my device reboots every time I install Xposed.
I hope someone does have another Idea, I really miss xposed
johnethan763
