Having sound problems in Android Auto? Try this
dby2011
248
FYI- received my USA Honor 7x yesterday. I'll try to have a brief review of it soon here. I did come across an unusual issue with the phone concerning the sound quality when using Google Play Music in Android Auto. The sound was horrible- very flat and no bass. When I switched to bluetooth it sounded fine. I also switched cables and it made no difference. After playing with multiple settings I figured out it was the Huawei Histen sound effects setting for the headset that caused this. You need to plug in a pair of headphones, make sure the setting is turned off, unplug the headphones then start Android Auto. Very strange issue but this seems to have solved everything. I thought I should post this in case others have this issue. I assume once US Amazon gets this in stock this forum is going to take off and someone will have this issue.
FahadsTech
