Hdmi interface, no sound
ykariv
Active member
Oct 29, 2012
38
What did I forget?
Connected note 10.1 using samsung hdmi adapter. Got picture but no sound from the external tv. Just from the note. What did I do wrong ?
thanks
Sent from my GT-N8010 using Android Central Forums
Did you plug in the power connector? - it is required.
I found that I had to increase the volume on my Sony TV from a normal of about 20 to 50 to get good volume.
Yes.the power was connected and volume was max
I found the the problem
My vid cable is good for dvd (vid + sound) but not good for tablet (no sound)
New hdmi cable solved the issue
No. I got it with Samsung's dvd but it is a standard one just the new/current cabel 'model'
I have the same problem. The Rocketfish HDMI cable doesn't work. Video no sound. Some have recommended turning the volume on the TV to max. Others have suggested audio patch cables through the headphone jack. I just want an HDMI cable that works.
Sent From My Samsung Galaxy Note 10.1 Tablet
Which HDMI adapter from the Note are you using? Where did you get it?
Jesus H Christ are we still dealing with this crap neigh on 2013? There are so many products and variants of products it's like you have to be a bloody engineer to research all the nuances before you buy anything. Most people would have thought a HDMI cable was a HDMI cable. I was wondering why the sound didn't work on mine too. So are there two types and how do you distinguish if it's once that also does sound when you buy one?
I got hdmi interface at ebay.it is the original one and work perfect. Just first you have to connect it to the power before conecting to the hdmi cable, otherwise it may not be showed on the tv
dspau94
