Headphone adapter help
Clive Salvacion
3
Hey guys, I need help looking for a headphone adapter because my headphones do not fit because of my case (seidio surface). Which ones do you guys recommend and will fit a case with a small cut out?
OK I'm confused why won't they fit.? . I'm using an otterbox defender and still have room. Unless you might be using headphones with a 90 degree bend I'm assuming?
Sent from my HTC One using AC Forums mobile app
If you look at the mophie battery cases they come with a small headphone adapter to make up for that same problem. I'm sure you can eBay that same adapter.
asnes
