Headphones for Nexus 5
Re: Headphones for nexus 5
If you want to customize the functions of the in-line controls, you might want to consider buying the app 'Headset button controller'.
Yours sincerely,
Brian
Sent from my Nexus 4 using AC Forums mobile app
I just noticed this too and am pretty excited about it! Totally wasn't expecting the controls to work since they didn't for my Nexus 4. :D
That's great because I just ordered some for 40 bucks on Microsoft Store.com couldn't pass that up
Sent from my Nexus 5 using Tapatalk
I recommend the Klipsch s4 ear buds. They're available both with or without an inline mic. I've had two pair and the sound quality is awesome. They even have a rugged version.
I have them as well and coming off of using them with my old Galaxy Nexus they really shine on this phone!
this is OEM -
Premium Wired Mobile Headset With Excellent Sound Quality And Minimalistic Design
WIRED STEREO HEADSET
HSS-F420 BLACK COLOR : Black White
TRUE-TO-LIVE SOUND BALANCE CAPTURES A WIDE, EVEN, HI-FIDELITY SOUND RANGE
SOLID BASS TEXTURE WITH VERY LOW DISTORTION
DOUBLE RUBBER TIPS PROVIDE ENHANCED SOUND INSULATION (3 SIZE EARBUDS)
ADD TO CART
Where To Buy
$29.99 Suggested Price
ADD TO COMPARE
This premium wired mobile headset combines excellent sound quality with minimalistic design. The canal-type earphone with aluminum deco comes in sleek black or bright white. Enjoy solid bass with low distortion and a wide, even sound range that captures a vivid, true-to-life high and low pitch sound balance that’s close to hi-fi sound. QuadBeat is the perfect wired solution when you're on the go!
LG HSS-F420 BLACK: Premium Wired Mobile Headset | LG USA
Its becoming more and more common to not include the crappy headphones that used to come as an accessory to the phones. They're so bad that it's almost a good thing that they leave them out as it may force you to actually spend $10-$20 on something that will be far better than what they included. I know not everyone agrees with that but it is what it is.
OptimuS G Pro
The dont my sennheisers have no volume control not made for android.
If you want to be able to control the volume from the headphones you'll need headphones made for smartphones (w/3-ring 3.5mm minijack). Regular headphones may give you better audio but you may lose the ability to control volume etc. from the headphone cable.
OptimuS G Pro
Hi There so all of the Klipsch 4s work on nexus 5 including volume control?
Yes I am aware of that but I need earphones that will fit under helmet, be noise suppressors and have all remote options. I cant try them on when they are in sealed boxes online or in-store so dont know if the volume control will work and whether they have a good sound or not. And for that matter nearly all in-store ones are Iphone these days.
If you want to be able to control the culume from the headphones you'll need headphones made for smartphones (w/3-ring 3.5mm minijack). Regular headphones may give you better audio but you may lose the ability to control volume etc. from the headphone cable.
OptimuS G Pro
So it sounds like you'll have to actually purchase them to try them.
OptimuS G Pro
I also use the Apple Pods and they do sound real good, I wish we could use the click buttons. I am not able to.
The Klipsch S4A works with Android. There is a Klipsch app in the Play Store that you download. It works on my wife's SIII. These have a patented ear cup shape that no one has. My wife says these are the most comfortable in-ear headphones she has ever used; including my expensive Shure headphones. I have listened to them and I will be getting me a pair if mine ever fail. Kohls actually sells them now in the accessories area; $89.
Sent from my Samsung Note II using Android Central Forums
MichaelCrusan
