Hello - T-Mobile!
Yeah I have the 500MB free they give. Just curious incase I need unlimited. A buddy at work is going to want to tether from me lol.
Sent from my T-Mobile HTC One using AC Forums.
Almeuit I have been using the hotspot a lot this month. My counter still says 0 data used and my hot spot still works fine. I know I'm well over 500MBs. By just steaming Netflix on my tablet
Sent from my Coconut Wireless HTC One
Are you using the one built into the menu? Under the mobile data / sharing section?
Almeuit,
I'm using the stock tmobile account widget
I meant which tether app? If I use the built in one (see below) it seems to track the hotspot usage :(.
Almeuit,
Yes I use the stock hotspot widget
Fired it up... Let's see if it uses against the hotspot data. I hope not.
I'm using the wifi for root users app on the fact I KNOW it doesn't count against the data limit.
Sent from my T-mobile LG Escape using Tapatalk 2
This is what u call a whole family going hard lol.
58GB? Man your speeds and connection must be dang good. I am only at 27 GB
I actually see my hotspot at 46 MB lol. That's is flash. More like 4GB it should be
Damn Mell you use a lot of data man! Good job! What do you think your monthly use will be this month? Any guesses?
I used to average 6-8 GB a month with Sprint... Now it may be higher since I can use the data actually lol. Below is my usage over a few days.
I'd use a lot more data too but I normally only allow Google Music to stream from WiFi and pin it to my device. So it uses no data! :P Otherwise I might be able to break double digits.
2009sxs
