(help) Android sd card nfts problem
Laurens Knaepen
4
Hello,
What did I done?
I changed my sd card of my android to ntfs (ntfs is for you can put higher stuff then 4 GB on the sd card ,I needed that ,don't ask why ,I just needed a big file)
What's the problem?
when I done it, I found out I couldn't use my phone anymore on my pc (so I can see my stuff inside it) and I also found out I couldn't use the sd card on my phone aswell...
My phone
Samsung Galaxy S plus I9001
Custom rom Cyanogenmod 9
Rooted
What I ask
Is there any way to get my sd card back to Fat ,without getting my sd card out of my phone (I mean like ,it's inside the phone ,it's not a external ,I don't wanne break my phone)
I hope you can help me!
Thanks ,also thanks for response ,I didn't tested it out yet ,I'm gonne test it out now.
Sorry for late response anyway.
it didn't worked ,it's says stopped working.
and run it without adminstation then just pop up and goes
computer = windows 8 pro with media center
Well ,I tested it out ,and I first a ddl problem (I fixed that)
but now ,it stop responding ,or it just don't start if I'm starting it with adminstator
Screenshot by Lightshot
Computer
I have a windows 8 pro with media center
is it maybe cuz I'm windows 8 ,or other problems?
Wish I could help you more, but as I mentioned before, this is beyond my experience. Hopefully someone else can chime in ...
moon970
