Help, brick phone somehow
Ok...so the VERDICT..."IT WORKS!!!" Holy crap..I love android guys..I really need to get to studying more of this stuff. Sad part is I'm in college for computer science..man, stuff is changing fast...so biggest question for me now is...do I leave this zip file on my sd card for further fixes if I have this problem again or do I delete it??? Thanks again to all the feedback..
I have a roms folder where I keep it just in case.
Yea dude dont forget to Move that file off the Root of your SDCARD now
If not the next time you boot into Hboot it will attempt to load again
*I also have a Folder Labeled Roms where I have EVERYTHING!
I understand you guys created a rom folder but in hboot even if I have that file won't it just read my entire sdcard and look for what it can and load it? I actually formatted my sdcard and just have that one file on it now...I am going to create a roms folder for this but I guess I just need to mess something up again and go from there...all in all I guess you have to learn somehow..once again I appreciate all your guys' help...I have my life back..my phone!!
Depending on what you want to do, I'd install a custom recovery and go from there. This way (hopefully) you won't need to use that file again.
Awesome, glad we could help. If you are going to root again, I would recommend using this method. It's more time consuming but it's not hard at all as long as you follow the directions, and you learn a whole lot more than when you use Unrevoked.
No it only scans the Root portion...
Deelow
