Help - can't flash or wipe data / system
cotys
8
I installed CM 7.1.0 Beta. It has been running fine for weeks. I let the battery go out and started having forced closed.
The problem is getting rid of 7.1.0 beta. It will not let me update CWR. I can't wipe data and system. I have even followed manual instructions to update CWR, but when I reboot it wipes out my new install and goes back to 3.0.2.8.
Is there a manual way to wipe data and system with ADB? CWR can't do it even from a bootable SD card.
I'm at a loss.
(I attached the log from CWR and trying to format data)
