Help deletion issue
4 Star General
305
6
I Hv a folder in my gallery with the Picasso icon that's attached to Hangouts and won't allow me to delete the photos within. Only options are download and share. How the h3ll do I get rid off.
A Note 3 & a Wrangler, life is Grand.
Try this...Google up how to delete Picassa photo's from Google hangouts.....This should take you to a forum about just this...even have a video on it...so it can be done
Good luck
Sent from my SM-N900V using AC Forums mobile app
Try the following steps it will work
1) Go to settings click on Accounts and Sync.
2) Uncheck Sync Picasa Web Albums.
3) Come back and click on Applications in the settings page.
4) Now click on Manage Applications.
5) In the manage application page click the Menu option ALL.
6)Scroll down you will find an option called gallery.
7) Click on the Gallery and clear data. Note: Don't worry your local data won't be deleted.
9) Thats it check your gallery now there wont be any Picasa web albums in your Gallery.
You will still have to get on a computer and delete the pictures in Picasa as they are still there just not syncing to your phone now.
Vector
