Help going S-ON
May 29, 2013
6
Today my screen broke on my phone. Before I go to Verizon I want to go back to S-ON. I used he Moonshine method. If anyone can help me that would be great. Thanks
I know with unrevoked you could use the unrevoked forever zip to restore S-on but I'm not sure with the moonshine method.
I would go to the moonshine thread at xda, and look there, root devs generally won't publish a root method without a way to unroot.
I hoped that helped some, I'm pretty unfamiliar with the DNA, but I've been actively involved in the rooting community for two years now.
Sprint GS3 Running TN's Msg and Chubbs
Why bother? If the screen is really "broke" then the warranty is voided by that alone and is the only thing they will see when you bring it in. They won't replace it. If you're thinking of an insurance claim, Asurion doesn't care if it is s-off or not.
Breaking the screen is not covered under a warranty replacement, unlocked bootloader or no. If you have insurance, it is irrelevant as to whether you are s-on or not.
Jennifer Stough
Forums Moderator
Device: Droid DNA unlocked, s-off, rooted, running Hatka Supreme Sense 5.0, Android 4.1.2
Jennifer Stough
Forums Moderator
Uh.......echo? :)
Uh.......echo? :)
Sometimes people pick and choose through replies, maybe if enough people tell him the correct answer, he will see it and take heed ;)
Jennifer Stough
Forums Moderator
harristn
