help help help
sleepyrey
67
hey i just downloaded BAMF 3.0 everything went well BUT once it was completed i dont have no signal why is that i just got that "x" up top what did i do wrong please help
thanks
Have you flashed the mr2 radio?
If yes, wait a few min or try a reboot. Otherwise, you must use a compatible radio, try the official ota mr2.
Dl the radio, rename pg05img.zip, and place on the main directory of your SD card. Then restart phone in the bootloader.
There are in depth instructions in cyber warriors backups sticky.
I'm pretty new, so please take with a grain of salt. Do some searching of your own.
1 - get the new radio. Variety of sites.
2- rename it to PG05IMG.zip and put it on the root of the SD card (mount the phone).
3 - turn off phone
4 - press power and volume down to boot into HBOOT
5 - put the case back on once you have placed the radio in
I didn't get any signal. . .until I did this, all of it (even the case).
[Radio] [Leak] Official MR2 Radio 1.39.00.0508w, 0.01.69.0510w_3 - xda-developers
Ninja01
