Help help help
jholt92
my phone hasnt been able to go into recovery sometime now and i have a update and cant update my phone due to the recovery problem. i may have bricked it but im really unsure what to do i just want to go back to stock on everything can someone please help me?
We need to know more info, like what happened to cause you to lose recovery, what happens when you try etc. I am going to go out on a limb and guess you used rom manager to install cwm recovery and when you boot into it it shows only black.
Sent from my Nexus S 4G using Tapatalk 2
Yea thts what happened
if you can boot into android, go into the rooting/roms/hacks section, and download xionia and flash_image from that thread.
then:
place both files on the ROOT of your sd card. first level, not in folders.
then, using terminal emulator or adb, and from a root shell, type:
# mount -o remount,rw -t yaffs2 /dev/block/mtdblock5 /system
# cat /sdcard/flash_image > /system/bin/flash_image
# chmod 755 /system/bin/flash_image
# mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak
# mount -o remount,ro -t yaffs2 /dev/block/mtdblock5 /system
# flash_image recovery /sdcard/xionia_cwma_12518.6.img
# reboot recovery
dont type the # signs. this just signifies root access.
you might get an error on the
line. thats ok, and to be expected.
this should get you stock recovery. the thread you need is:
http://forums.androidcentral.com/lg...covery-xionia-clockwork-cwma-v1-2518-6-a.html
that thread contains the files.
good luck.
ps if you cant boot into android, this WILL NOT work.
koltyn
