HELP HTC Evo Shift soft Bricked?!?!?!?! HELP PLEASE!!
N16HTSTALKER
5
Hello I recently bought and Htc Evo Shift from a guy. And I didnt realize it was rooted. So Whent to sleep yesterday and tried to boot it. But it took me to a clockworksmod screen and i totally confused pressed some stuff to take me back. So i turned it of and turned it back on, and it stays in the Htc white screen and wont go any further Idk what to do heeelpp please!! I really need my phone and have no money for a new one. Ive tried and searched the internet but no luck.I can go to the clockworks mod screen and the Hboot screen. Ive tried reseting factory settings but it takes me to clockorks mod screen all the time help please!
I'm not around my pc right now but I'll diva quick walk through on getting your phone to boot. Look in the rooting and hacks section in the shift forum, find the sticky with the list of ROMs. Just choose one, download and put on the root of your sd card. Now, go back into recovery, you'll see an advanced, click that and wipe dalvik cache. Go back then click wipe cache, then go back and click wipe data. Once you have wiped everything go to install zip from sd, scroll and find the ROM you put on your card and click it. This will flash the ROM that you chose. Once its flashed go back and select reboot. You should be fine after that.
Sorry for the jumbled directions but I'm on my phone. If no one else chimes in ill walk you through it later.
Good luck
Sent from my Gingerbread Speedy 4G using Tapatalk
Good luck
hi thanks i tried that from reading on a previous post. I downloaded like 2 and nothing worked it reboots and stays in the same screen. Is there a specific one i have to choose?
Shouldn't matter which ROM you choose. Did you make sure you fully wiped everything?
I downloaded one called speedy but it didnt work. i delelted cache and user data about everything i could. :(
Tell me what Recovery version your running. In clockworkmod what's the version at the top??
Worse case scenario you can use this One "zip" RUU-Back to stock-2.3 zip removed completely - xda-developers
This is a one zip ruu that will return phone completely back to stock. *Unless you remove the hboot and recovery from within the zip this will cause you to lose root* Download the file and place it on the root of your sd card, then go into bootloader. Bootloader will recognize the image and prompt you to flash. This will almost definitely let you be able to boot your phone.
I am curious to why you can't get a ROM to flash though.
Yes that would be great because when it was rooted i couldnt install the newest upgrade of OS Gingerbread it would download and then when i tried to install a triangle with exclamation mark would appear. I really dont care about th root. I just care about getting my phone back. xD The version is 2.5.1.8
OK your problem is your recovery is old and the ROMs aren't compatible.
Download the file in the link. Place it on the root of your sd card, make sure it's still named PG06IMG.zip. Boot your phone into bootloader, and it will recognize the image and give you prompts to update.. Let it do it's thing, then reboot.
Ok thank you I will try it and give you feedback on what happens. Greetings
i want to know if this could work for the regular HTC EVO 4G,I rooted but i screwed it up trying to get the recovery on it,all it does is going to the bootloader by pressing Volume down+power button.If i just decide to turn it on,it just get stuck in the HTC EVO 4G screen...Help please :( :'(
please read what i just posted in here :(
Could you be a little more specific, can you get into recovery?
Get the ruu file, connect the phone to your computer, and flash it that way. Has helped me out a few times and never fails. Just make sure the battery is charged.
Help Please I rooted my evo shift 2.3.4 with clockwork mod and I wen to put a rom on it and it got stuck on the white htc screen It wont go back to clm recovery just the stock one. I tryied to do a factory reset ond it looks like its going to work then the htc screen i unlocked it with the htc dev tool on the stcok recovery screen it says speedy xe ship s-on hboot-1.08.01.0111 emmc-boot dec 29 2011,10:29:48 . Can someone please help me out im new at this and im thinking i messed this up:(
Your phone is fixable, don't worry. Simply follow the same instructions posted in this thread about the RUU, or fastboot flash a custom recovery again.
Sent from my Nexus S 4G using Tapatalk
i have tryied and tryied both of the ways here in this post but no luck and the ruu gets stuck at 14 % adb dont pick up phone
UI got it I feel like a dummy now it was so simple, bim now per rooted with s off. thanks for the help:p
dsridar
