HELP I am rooted and regretting it
nicknicknickh
11
OKay so I rooted and now am regretting it help? I used unreovked3 pc version to root and am running a custom rom I believe the CyangoenMOd7
How Do I unroot?
I need the fastest possible I dont mind loosing contacts etc
Will I need to reactivate my phone?
I cant seem to format my sd card to fat32 anyone got suggestions? When I plugged my phone into comp the select like disk drive thing did not popo up what do I do?
click on my computer right click on ur sdcard, click formet select fat32. or is your pc not reading your phone? with cm7 you have to select mount usb
ok plug in your phone to ur pc in the status bar pull it down and change it to mount storage forgot what it really says... ignore the usb debug one
if you want go into recovery plug your phone . select mounts and storage then click mount usb storage (THIS ALWAYS WORKS)
any way we can chat?
PS: I was able to format my card to FAT32 :) can we still chat because these guides are for tech people like you who are geniuses
Masterknowledge
