Help!!! I m stuck in recovery mode
Ky1e.YC
374
Guys, a little bit help here? I haven't done any root part yet, just try to install adb driver on my pc. I followed instruction and entered recovery mode, unfortunately, my windows7 didn't find adb device yet. so i decide reboot my phone. Unfortunately there is menu, so i m stuck in the recovery mode, how can i get my phone reboot????? thank you
If Reboot the system is selected (can change using the volume keys), press the power button.
i got it. hold the volume up and power, you will have menu. then i select "reboot". everything's good now. thank you
Thanks a ton for this.. i was stuck in the recovery mode too with a triangle and ! sign on screen and with nuin else. saved me. :D
When i do it, it shows me "Error" And then it restarts and launches up the menu again (Note, i do not wanna lose my data. at any cost)
najufatx
