[HELP] LG G3 Stylus (D690/93) Volume Boost
Barto604
5
Hello Everyone,
As you know the LG phone's volume are terribly low, no exception for this model, I was wondering if there's any app or system file i could tweak to increase the volume sound for the ringtone.
The methods i tried are:
- Installing the Volume Booster LG G3 (root) app from the play store:
Status: My Device is not supported for this app.
- Open the File Manager app and then go to the “/system/etc” folder;
Find a file titled “mixer_paths_qcwcn.xml” (for the D855 model) or “mixer_paths.xml”
Status: Those both files are not in the system/ etc folder of my cellphone
- Increase the volume of my ringtone mp3 file
Status: The Audio quality got bad and the song sounds distorted
Device Info:
Model Name: LG D693 ( LG G3 Stylus)
Android : 4.4.2 Kit Kat
Root: Yes
Any suggestions really appreciate it,
Anticipate Thanks,
- Barto604
How much did you increase the number by? That setting in the mixer xml is VERY sensitive, and might not work the same as the D855/Normal G3.
Oh, I see what you mean. Not sure if I've seen any ways of increasing the volume for this model as it is not as popular.
Some recomend me viper4android (forgot the name and im on mobile) but i don't understand the settings to boost the volume of the speaker.
Droidikon22
