HELP!! loaded gingeritis and lost root and will not reboot into recovery!!
jamushaggard
9
Yesterday i loaded Gingeritis Rom came home to load A different rom and went to use Clockwork MOD and found that i had lost Root. Went to reboot into recovery and it wont go it just restarts the phone. Also now my PC will not recognize my phone TO re-root or get to ADB.
If you loaded gingeritis then your Obviously rooted, try setting ur phone to Internet pass thru let the drivers install then switch back and your computer will recognize your phone. Did you flash the gb radios before you put gingeritis on it, and you did you can't flash a froyo rom on your phone without reinstalling those radios or you will get reboot issue's. Did you try installing busybox from market and installing the permission from that?
Reactions: nate44
themachine959
