Help me save/root my optimus v
Try this enable USB debugging from developers menu then power down then hold volume down + home + power. Phone should Boot into recovery. Try plugging in USB and connecting to adb from here in the recovery.
ill give this a try when I get a chance and let you know
- - - Updated - - -
I was meaning try the USB hub if you have one around somewhere. Some phones won't connect on high-speed USB ports all the time so with the hub in-between to slow things down it may work but I'd try to ADB while in recovery first
i do have one, but like i said in OP it did work when i originally bought the phone, but has since ceased
tried hub, no dice
How long have you had the phone again? If it's been less than a year, VM might replace it for you.
doing this then ./adb devices still shows no devices
kitlis
