Help me to choose between Active 2 and GT2
  • Start date Start date
A
Android Central Question
My background and needs: I am using classic watches for years like Tissot and replicas of IWC and Panerai which are my favorite brands. I am a bit tired of replicas quality that are like lottery, lately I had a broken crown with a brand new one.
So I am searching for a smart watch not really for fitness like many people do but for the look and quality of faces.
2 models came in my budget and are pretty sexy: the Huawei GT2 and the Samsung Active 2
Which model do you recommend me?
Is there a real life difference between 1.39 and 1.4'' for an astigmatic dude like me? I don't want to put my near sight glasses every time I want to check the time
I came to this comparison after some research but I still can't decide:
GT2:
+Cheaper and more available in my country
+More classic look
+Higher resolution screen
+Awesome battery life
- Limited apps
-Limited faces
-No animated faces?
Active 2:
+Cool design
+Cool scrolling frame
+Can add apps though I guess there aren't a big choice
+Better OS/ menus
+big choice of faces with animations and even sound
-Weaker battery (2 days max)
-More expensive
-Difficult to find in my country due to the economical crisis (Lebanon)
-Paint! Unless I pay even more for stainless, the aluminum ones are prone to scratches and this is a big negative for me
I had a Samsung wear watch last year. Sorry to say but I found the real life battery life was dreadful. A day at most. As a pebble user I was used to 5 plus days. The screen was slow to respond and I personally found the whole experience expensive and a real let down.
I cant say about the GT2 but do a little research into something like the Amazfit range (check AliExpress) I think they're the same company or a sub brand. Also use the android system.
Hope this helps
mama baer
