Help. Mic not working with these ROMs
Rudeco
Banned
Jul 26, 2012
129
3
When I use Tango with my regular headphones ( without an inline mic), the mic on the phone won't pick up my voice while the headphones are plugged in. It used to work fine like that on OV stock rom, and I think BACKside IHO. Anyone have Tango and can test this and lemme know which ROM your using?
This doesn't work on any ROM (including Backside). It's a bug throughout our CM7, CM9, and most likely CM10 ROMs as well.
Only thing I can suggest is if it's really that important to you, go back to stock, or try one of our Froyo based ROMs like Harmonia 1.
Xtmanual
