Help my zenfone2 dead
alexg1993
3
I charged my zenfone2 ze551ml over the night and it charged only 50% and after 5min of using its just shutted down and wont turn on i tried different cable and adapters and still the same
I also cant get into recovery mode the screen tottaly black and just vibrating
Help?
Welcome to Android Central! What happens if you press and hold the Power button? Does it vibrate? Does it seem to be on, but just the screen is not working?
And is it vibrating constantly, or does it just vibrate once when you try to power on? If it's vibrating constantly, then there's probably some major hardware malfunction. If it vibrates only once, then perhaps it's just the screen that's damaged. Either way, you should contact ASUS for warranty repair.
Its just vibrating twice and not showing anything ptobably hardware/battery problem.
How ever i will give it to repair center its under warranty.
That's probably the best approach. Good luck!
Is the power LED indicator light on when charging? Please try long pressing power button for at least one minute without charger connected. Then connect charger, check if power LED indicator is on and let charge. Then try powering up again.
Sometimes re-seating the battery can help resolve this type of issue however for this model the battery is non-removable and will void the warranty if taken apart. If you have tried other cables and/or chargers and unable to power on it may require warranty service. If you have any questions, concerns or would like warranty assistance, please feel free to contact me direct at cl-frank@asus.com
Sincerely,
ASUS_USA
Sincerely,
ASUS_USA
I am going to give that a try with my dead ZF2... can I reach out to you with warranty concerns as well?
Hey alexg1993
Keep your phone on charging for 4-5 hours & check.
Use Asus OEM charger
suuu
