HELP need opinion
Thats just the camera making the rattling noise I think, nothing to worry about.
yes but all nexus 4 has this or just mine? =) it's annoying and its Its 5 days old!! When I put it on table I hear this sound jaoooooooo LG
If its just mine than I want new one! =)
Mine is a month old and it doesn't make that sound. Get it replaced.
Mine does it too.. Ive posted about it in other threads.. I was also unsure if this was normal or if it was just mine.
Edit, a quick search resulted in finding this post by palitsyn
The rattle is the auto-focus. It's normal and is not an issue. Here is how it can be proved that the rattle is in fact the auto-focus. Turn the camera on and start tapping the top of the phone. You will hear the rattle. Now focus on something really close and keep tapping. The rattle will go away.
I tried this and palitsyn seems to be correct.
It is normal. Auto focus in camera is rattling, not needed to be replaced because you will get probably the same :)
Yea but it shouldn't rattle! its year 2013=) f....
Yeah, because rattles don't exist IN THE FUTURE!!!
In all seriousness, it's normal. Mine does it too. You get over it. Or not...but then you may have bigger problems than a phone rattling. :p
Groundhog349
