Help need to unroot!
kaivorth
Active member
Jun 9, 2011
43
Sold my Optimus V with a custom rom, roooted. The buyer went to activate it and couldn't. He has a feeling it is because it is rooted. Easiest way to unroot the cellpone?
It's on 2.3.7 with a custom recovery too.
Conveniently enough there's a link to Harmonia 1.8 in LeslieAnn's signature. I would recommend fixing with Rhode and stick with the gingerbread ROM though.
Reactions: inceyet
Just flash the ZV9 update....that'll do it ! :D
really should know what custom recovery is on it before suggesting this... if he has cwm green, blue, cwmt touch, or multirom then your suggestion would take a lot of work to come back from.
really tho if he wants to stick with the GB rom then i'd also suggest make a backup then use rhode to activate and then just restore the backup. if he wants full stock (yuk!) then he'll need to have bobzhome or iho recovery to flash the update.zip from virgin
+1 to that! ^
Miserydhala
