HELP!! nobody can receive any of my (mms) messages
Let us know how it goes! Doing some yardwork, but will check back when done. ;)
Okay I give up.... I called 611 (customer service) and they refreshed the phone two times and still I can't send MMS. I can receive them just can't send any... So they are going to send me another phone I just hope Its not updated so I can still s-off and root... I have truest everything I even flashed the stock rom nothing worked I even went back to the last radio ota and still didn't do anything... What else could it be that's the only thing I ever updated was the radio from xda... And I also removed a file from the Wimax folder that people say will boat your 4g but that should have nothing to do with this problem... This was the first phone i ever rooted and flashed ROM on... I'm still a noob and learing new things everyday ... I appreciate all the help everyone gave me... When I get the new phone i just have to be careful on what I do........
Since you've already made up your mind on that and have another phone on the way, I won't try to convince you on that. :p But, I will say, I never updated my software (as well as others I've talked to) and they don't have issues with it. I suggest not accepting the OTA updates and trying jondevere's ROM since you seemed to like it. ;) And, you should have no problem with mms! :cool:
No I never have updated any ota....
I'll bet its all part of the same problem me and others are having by not being able to send or receive sms messages. I dont know if the new phone will be any different since I think it's the sprint network. They promised me a monetary compesation so I suggest we all call for one,maybe that'll get them off their a** to fix this problem.
Really? Can you send MMS? I called and they waved the 35 dollar fee to replace the phone so idk what's going on... Idk what ****ed up on my end or there end.
another issue... if you send them back your phone and you have it rooted with custom recovery and a custom rom... you may be getting charged for your replacement. Not to scare you but you did void the warranty. A quick return to stock would be the FIRST thing I would do. Just tryin to save u the headache and cost of telling sprint u hacked their stuff :cool:
have you used an app(Quick Settings) to turn off/on data? i did and had to fix my apn before my mms worked again. apn backup and restore on the market will allow you to backup and edit it(youll see apn and mms with a [Disabled] next to it. get rid of the [Disabled] then restore from the edited file) . might not be the same problem but thought id throw it out there
Okay ill give it a shot... I'll tell u if it worked
Patric2204
