Help! Phone wont go past AT&T screen
ninamcclain93
3
help! My phone wont go past the AT&T start up screen. It doesn't show up on my computer either when I connect it via usb. I don't know how to fix it. I can't afford to buy a new phone. HELP!!!
have you tried pulling out the battery while it was on and then starting it up again?
yes, nothing happens. now when I plug it in to the charger, it shows the battery, but doesn't show it charging like normal. and when I unplug it, it just keeps the battery picture on the screen.
well that's my limit of expertise lol. i've never had an issue that just removing the battery didn't clear up. there are some recovery modes, etc, but i don't know anything about those.
i'm sure someone will come along that can help you, good luck!
just to be clear, your device is a samsung captivate? what about calling at&t, on another phone of course. you might also try searching the forums. :eek:
zonpeter
