help please....double icons issue
david7598#AC
Active member
May 10, 2010
35
im on myns rls 5.....and this is the first time ive had this issue....i found someone had this problems awhile back but i cant find the post anymore. when i move an icon....the duplicate is under it....how can i fix this.
I had this happen before, i can't remember the exact way that we got it all fixed. A very easy fix is to just long press and delete all the extra icons from every screen.The other way is to fully wipe everything then install the rom again and problem solved.lol
Touch the app icon you want to delete. Hold your finger on it till a trashcan appears on the upper right hand corner of your screen. Drop duplicate icon into trashcan. It's deleted!
Hope this helps. I'm new to Xoom. ;)
Thank you , I just received my new Infinity and was frustrated trying to remove those duplicate icons.
I want to add that running stock ICS the "X Remove" is located in at center top of your screen, and in my case, barely visible because of my light background.
Thank you again.
KidColoringPage
